Fram TG 3600 and Valvoline Restore and Protect.
I think the switch to the ecore design will help fram. The supertech/AC Delco production lines certainly look better.
The E-Core be slipping also. I recently had a E-Core FRAM PH10575 that was disbonded from the fiber end cap and the wide pleat spacing join seam
Just to clarify ... the end cap bond is with the pleat ends, so the center tube, be it metal or nylon, shouldn't matter. Same goes with the bond between the pleats and metal end caps.
Where the seam, pleat end and fiber end cap meet, it was disbonded across 3 pleat ends.
Fram Endurance FE 3600
