Fram response to inquiry
Huntington Beach, CA
Not bad???
To whom it may concern:
Thank you for the e-mail regarding the difference between the Fram PH8316 and PH3600 oil filters for your 2002 Ford Focus with the 2.0L DOHC engine. We welcome the opportunity to be of service.
To confirm, the PH8316 is the recommended Fram oil filter for the 2002 Ford Focus with the 2.0L (16 valve) DOHC (3) Zetec and DOHC HO (5) engines. The PH3600 is recommended for the 2002 Ford Focus with the 2.0L (8 valve) SOHC (P)
engine.
Our Ford research data identifies the original equipment number F8CZ-6731-AA as the Ford filter used on the 2002 Focus with the 2.0L (16 valve) DOHC (3) Zetec and DOHC HO (5) engines. The original equipment number E4FZ-6731-AB is used on
the 2002 Focus with the 2.0L (8 valve) SOHC (P) engine.
Therefore the PH8316 and PH3600 are the respective Fram equivalents. The PH8316 is also equivalent to the Motorcraft service filter number FL2005 and the PH3600 is equivalent
to the FL400S.
Both PH3600 and PH8316 filters have the same 3/4"-16 thread size and anti drain back valve requirements. They are comparable in length and outside diameter. The difference is that the PH3600 meets a burst pressure requirement of 200
PSI and the PH8316 meets a burst pressure requirement of 265 PSI. Further, internal relief pressure by-pass valve requirements are different. The PH3600 has a 12 PSI rating and the PH8316 has a 14 PSI rating. The PH8316 also has an anti siphon valve to meet the requirements of the specific Ford original equipment filter used on the 2.0L DOHC engines.
The PH8316 is the recommendation that Fram stands behind and endorses as the filter application for the 2002 Ford Focus 2.0L DOHC engines. While both filters will spin on to your engine, they are not considered to be interchangeable due to
their internal differences.
As a professional courtesy, please be advised that the use of any Fram filter installed beyond the recommendations of the current Fram application catalog will void any warranty, explicit or implied, on the part of Fram filters.
No liability should be attributed to Fram for the misuse or misapplication of its products.
Thank you for choosing Fram filters.
Cordially,
Scott Jacobs
Catalog/Technical Service Representative
Catalog/Technical Service Department
verbose, and many parts did not look like a form letter.
Waiting for them to make one model with a 13 psi valve and say it's due to "manufacturing tolerances".
That's actually a pretty decent response. It brings up other issues with going to an oversized filter (e.g. burst pressure). I'll give Scott Jacobs at Fram a couple of extra points for taking the time to craft a well thought out reply.
[ October 16, 2003, 10:11 PM: Message edited by: Rick in PA ]
Pretty good response.
An actual letter not like many companies an one size fits all form, that answered all sorts of questions except the one that was asked.
Fred..
