Fram Extra guard oil filter for a Harley
wisco guy
Does anybody use their Extra Guard filters for motorcycles? The Extra Guard is a good car filter , does that hold for their bike line of filters also ??
For my bikes, FRAM says to use a PH6022. I’m currently running an OG FRAM Titanium FS3614 on my 2018 Tri Glide. I’ve also used an OG FRAM Ultra XG3614 on my ‘89 Electra Glide for years. Better filtration than the Extra Guard and no issues. If you compare the specs of the PH6022 to the 3614 they are almost identical, including the bypass valve setting.
while not the same I used Fram Orange cans & Autolite White cans (commercial account filters that saved me $$$) on an '06 Honda Shadow 750...no issues during the time that I owned it from 2015-2017 doing 2-3 oil changes/yr (less miles than recommended oci due to shearing via clutch)
As for my Harleys, I use the HD filter for the 5 micron rating - the Fram 6022 is rated at 10 micron so might be ok??
No question in my mind that the Harley Davidson OEM filter is more robust, I just think the price is really getting out of hand, but anyway, I put a Fram on last fall, and one other time in my bike 10 year history I have used one, they seem OK to me and certainly convenient.
One big plus I like about the Harley filter is Harley makes the special filter wrench that gets around the sensor on the Harley Davidson Rushmore engines.
Another great filter that I think competes dead on with the Harley filter is WIX 57148
I think they even point out it’s the same micron rating.
The funny thing is I ordered on two separate occasions WIX off Amazon and they came in dented and that’s how I ended up buying a Fram online from Walmart or something like that at a better price so I’ll probably keep using the Fram.
The WIX is a bit wider and more of a challenge getting around the engine sensor
@GMBoy
Not sure what engine you have but one thing the HD filter is and that is synthetic material. I believe the WIX is, dont know about HI-FLo but I had an issue with a Hi_flo, cold starts I would get a tapping for a second or two longer than I was comfy with. not sure why and does not mean it would happen again but not for me.
Does not happen with Fram, HD or Wix. Dont know why it did with Hi-Flo
Fram is a paper filter.
According to Amazon the WIX 57148 is paper too but I am sure that is not correct, I thought it was synthetic too. HD is synthetic
Wix on Rock Auto is $9 and Amazon $14
Here it is, Wix says its synthetic (glass) It even mentions the by-pass valve setting, which by the spec of that low setting you know this is a true motorcycle filter
https://www.wixfilters.com/Lookup/PartDetails.aspx?Part=1721791
@GMBoy
Thank for taking the time to share all of that information! I have a Twin Cam 88B (Softail Duece) and a Twin Cam 96 (ultra classic).
All the V-Twin parts site states is: “Micron rating of 10 traps microscopic dirt particles without restricting oil flow.” They don’t reference any ISO spec.
The FRAM website does list the specs. It’s 95% @ particles greater than 20 microns. Remember, the PH6022 is an Extra Guard oil filter. As far as I know, the specs for the PH series Extra Guard filters are all the same.
https://www.fram.com/products/oil-filters/extra-guard
True ... and they also show that same efficiency specifically for the PH6022 on their website. 95% @ 20u and greater.
https://www.fram.com/fram-extra-guard-oil-filter-spin-on-ph6022
Also for the chromed version. 95% @ 20u and greater.
https://www.fram.com/fram-extra-guard-oil-filter-spin-on-ph6065b
