- Joined
- Sep 1, 2024
- Messages
- 1,159
The “O” on the valve was the item in question.No lasers involved, or "laser etching" seen. It's just a poorly mechanically stamped out piece of metal.
Ok, now I know what you're saying. That wasn't laser etched, just part of the molding when the part was made.The “O” on the valve was the item in question.
We are unlikely to get any test results so have to use judgement on the information and knowledge we have.Technically, we don’t have solid proof that stated performance ratings are erroneous.
At least not yet.
Yes, and so we come full circle to results shown by BR on Endurance. If it was a “leaker” (I say likely) what would your “judgement on the information” be then?We are unlikely to get any test results so have to use judgement on the information and knowledge we have.
They showed the leak area on the PH ... it was discussed someplace, maybe in this 35 page/686 post thread, lol. They didn't know about ill fitting and leaky leaf springs when they did those videos.If you believe BR results are accurate. Which I don’t. The FE and Amsoil were non leakers. The XG, TG, and RP were leakers.
Yep, this thread probably should’ve been locked long ago.They showed the leak area on the PH ... it was discussed someplace, maybe in this 35 page/686 post thread, lol. They didn't know about ill fitting and leaky leaf springs when they did those videos.
This might be a "don't lock the merry-go-round" discussion thread record.Yep, this thread probably should’ve been locked long ago.
Yes, there are some ranking of efficiency correlations that don't rank like they would from the official ISO 4548-12 efficiency data would rank on the same filters.All the 99% and 99+% down to 20 microns should be equal to or better than the FE, and much better than the Boss. So either the results are bogus or the under performing filters were leakers.
But we have WC video showing Amsoil (AKA “Fram Clone”) as a leaker, right?Amsoil were non leakers.
The particle counts too.This might be a "don't lock the merry-go-round" discussion thread record.
The Amsoil and FE were not leakers in the BR results(if you believe them)because they were similar. The XG, TG, and RP should also be similar, but their not. Thus the leakers are exposed. All the 99% and 99+% filters tested should be almost equal in particle counts.But we have WC video showing Amsoil (AKA “Fram Clone”) as a leaker, right?
The particle count rankings don't rank the same as the official ISO 4548-12 rankings. There has to be reasons for that. The Boss is a good example. The exact filter model that BR tested has an ISO efficiency Spec Sheet from M+H/Purolator that shows it is 99% @ >46u.The particle counts too.
Exactly!!The particle count rankings don't rank the same as the official ISO 4548-12 rankings. There has to be reasons for that. The Boss is good example. The exact filter model that BR tested has an ISO efficiency Spec Sheet from M+H/Purolator that shows it is 99% @ >46u.
Really? That’s your logic? The results should be similar if they BOTH have the same bypass status….whether it be leaker or not. Conversely, there should be disparities if one is and one isn’t.The Amsoil and FE were not leakers in the BR results(if you believe them)because they were similar.
Follow me for a second.Really? That’s your logic? The results should be similar if they BOTH have the same bypass status….whether it be leaker or not. Conversely, there should be disparities if one is and one isn’t.
So the only conclusion we should come to Is that they were BOTH one or the other, but not in different categories on leakage.
This is the exact reason for iso testing. The results are repeatable. A properly performing filter will have the same results when tested again. The companies then are able to advertise 99% down to 20 microns for example.Really? That’s your logic? The results should be similar if they BOTH have the same bypass status….whether it be leaker or not.
Yes, but that doesn’t prove the status of the BR tested Amsoil filter.But we have WC video showing Amsoil (AKA “Fram Clone”) as a leaker, right?
So now we’re back to the dead horse thats been discussed in dozens of threads on BITOG for over a year. The BR results are not accurate or repeatable so we’re debating garbage data…..leakers or not, no way of knowing.Im not making claims as to the accuracy of BR tests.
| Tester | Filter | Efficiency 21-38 Microns / 20-40 Microns |
| Brand Ranks | Royal Purple | 91.3% |
| Brand Ranks | Fram Ultra (New) | 94.9% |
| Brand Ranks | Fram Endurance | 97.3% |
| Brand Ranks | Amsoil | 99.0% |
| Ascent | Royal Purple | 99.3% |
| Ascent | Fram Ultra (OG) | 99.9% |
| Ascent | ACDelco Gold | 97.7% |
| Ascent | Purolator Boss | 77.0% |
| Ascent | Wix XP | 71.4% |
