^^^ Looks like both end caps are the same configuration. Does the leaf spring fit into both end caps the same, or is there any difference detected? Can you make the leaf spring sit down all the way and contact the raised ring? In the past, most Fram filters only had the raised ridge on on end cap. They probably use the same now to cut down on having two different end cap styles.
