- Joined
- Nov 23, 2021
- Messages
- 467
Forged vs cast wheels. Which is better and why? Thanks
"Forged" means that the wheel started as a hunk of alloy, likely in the shape of a wheel. The manufacturer then uses a computer numerically controlled (CNC) machine to machine off the unwanted alloy. "Cast" means the manufacturer filled a wheel cast or mold with molten alloy. The surfaces of the resulting "wheel" are machined by a CMC machine.
Forged wheels can be made with less material because the aluminum is more dense and stronger. They are very light, typically 20%+ lighter than a cast wheel of the same size. An alternative is a rolled or flow formed wheel. The barrel is rolled in a press which hardens it and the spokes are cast aluminum.
