Originally Posted By: Wolf359
I believe 2003+ had the weaker spline on the transmission, but it's still a [censored] shoot, there are those out there that still last 200k plus even with the weaker spline. The AX4N was the better transmission, N meant it was a non synchronous transmission which meant you could jump gears from 1-3 or 3rd to 1st. The cloudy coolant tank is nothing, just the way the plastic is, probably dirt on the tank, I've seen much worse.
I was impressed by how clean looking the coolant was, no concern about the cloudy tank plastic.
Is there a VIN element way to determine if the transmission is the better "N" series transmission?
Duratec is automatically the AX4N, on the Vulcan it can be either and then you just count the bolts on the transmission. It's the KYB or Moog struts that are $75-$85.
Exactly, mine is a vulcan, so the S intead of N...
