Originally Posted By: Michelob
I bought a 2003 Ford F150 about 6 months ago. I had the starter(rebuilt) and flywheel replaced under warranty. A couple months back had the alternator replaced a brand new one. Truck usually starts and spins over real good no matter how cold. I have recently found out that when washing the car in real cold weather the truck will not start the next day. The battery is good. Get a noise almost like a slight click and nothing happens. Last time a few days later it warmed up and it started right up. After washing I can go out 2 hours later and start it, seems to be after it sits overnight. Maybe the starter freezes? Any thoughts?
Hello --- Fellow Ford F-150 owner of the same generation here... Do you have one of the Triton V8s or do you have the 4.2L V6? I myself have never experienced trouble starting my truck. I've always personally thought that, with a good battery, and no problems with your wiring (wet, corrosion, etc.), the Triton engine is very dependable. I've started my truck when it was -17*F (not even full-syn oil in it!) - just turned it over, only having to hold the key for like 2 or 3 seconds and she's alive!
Without having even heard your answer (as to what engine you have), I wouldn't hesitate to guess your problem - if water got under the hood somewhere important and froze, that could be why it wasn't starting. Especially considering how you said once it warmed up outside it started up.
Triton
