I'm not saying that this is going to destroy your transmission. Likely nothing at all will come of it... but if you're going to the trouble of a home flush, then it means that you're trying to get every last little mile out of that transmission. To that end, I think you're unneccesarily introducing potential problems.
The front pump will be turning- which of course isn't a problem since the pump isn't being starved of oil. Also, the input shaft and foreward clutch hub (on pretty much ANY transmission) will be turning. These are going to be supported by bushings... and it doesn't do them any good to run without lube.
I think that slightly more frequent drain/fills may be a better approach. I know it's a lot of trouble to remove the pan, and I'm a lazy ba$tard myself. That's why I always weld in a drain plug the first time I drop the pan on a transmission.
