My parents '02 Escape with the 3.0L has been showing a P1131 and P0401 for some time now. I've wrestled with the problem on and off to no solution. The facts I know right now is that the Bank 1 Sensor 1 O2 reads 0 volts at idle or driving, the was obtained from Torque Pro. All other sensors read ~0.6 volts operating like they should be. We have already replaced that B1S1 once. It didn't change the problem.
For the P0401 I have replaced the vacuum lines between the egr valve, solenoid, and intake. If there is insufficient egr flow would that mean the egr valve is closed and if so would the egr tube be cool to the touch after running for 15 minutes? I'm having "writer's block" with this problem. Any insight would be appreciated.
