Ford Door/Window Control Module
ZeeOSix
$100 site donor 2022
PNW
2013 Ford Escape Titanium. Driver's door window would go down fine, but would only go about 1/3 the way up and then stop. Window didn't seem to be binding in any way. Slammed the door a couple of times and it started working again.
Next weekend I removed the door panel to inspect inside the door and didn't see anything mechanical that could have blocked the window path or caused it to bind. The window was still going up all the way at this point, but I did notice the window would not "auto up" like the other 3 windows, and would not do the "safety reverse" and go down if the window was "blocked" while it was going up. Tapped hard on the window control module (mounted on the door) a couple of times and the auto-up and window safety reverse functions started working.
But, I was also doing a lot of full up and full down test cycles and maybe holding the control button for a bit after the window stopped going up or down, so I'm wondering if I unintentionally "re-indexed" (reset) the window module like shown in the video link below without even realizing it, and that's why those features seemed to work again, and not from banging on the module.
https://www.youtube.com/watch?v=0b17hyZcrV0
Anyway, what are the chances that it really is the control module and slamming the door hard a couple of times or banging on it caused it to work again? I could hear mechanical relays inside the module, so it's not totally solid-state. Seems like it could be possible since just slamming the door on the first day this problem showed up caused the window to go up all the way when it previously wouldn't. Any ideas?
Has the battery been disconnected or replaced lately? That can cause problems and there is a reset procedure in the owners manual.
The battery was replaced about 2 weeks prior to this, but the window seemed to be working fine after the new battery was installed. I guess it's possible the control module got confused at some point from something else.
Try the reset procedure before anything else.
Yep ... even though it seems to be working now I'm going to do the reset again even though I might have inadvertently did it while testing the window. I ran across that window reset video after I worked on the door this last weekend.
I would expect the lube to still be viable after 5 years.
If there are mechanical relays, I would take the module apart and clean the contacts with an ignition file. Relays are a continuous source of problems for cars.
Yep, the grease on the window sliding mechanism looked pretty good, but I did add a little bit of white grease to the sliding mechanism since I had the door panel off.
