Propflux01
$100 Site Donor 2025
Replace a master cylinder on My Sis-in-laws 1976 Torino about 3 months ago. It was shot. Anyhow, all worked great, re bled everything,brakes worked fine. She calls me up today and says "no brakes'. I get the car, and she tells me that her front ( smaller) reservoir was empty, and she put fluid back in it, but still very spongy and the brake light is on continuously. I jacked up the car and there is not a drop of brake fluid anywhere on the wheel, front or rear, or anyplace. There was a slight amount that looked like it had leaked out the cover of the master, but none anywhere else. While I was pumping them, I did notice that on the proportioning valve, there is a little tit-looking thingy, almost like some sort of pressure relief valve, and it goes in and out with the pumping of the brakes, and sounds like a slight hissing sound to it. However, not a drop of fluid anywhere around it. i don't know if it is because there is air in the system or what, or whether it is supposed to even move. I had thought maybe I got a bum master, as the fluid is not clear, it is slightly brown, like fluid that has been in much longer than 3 months. When i originally bled the system after replacing the master, I used 2 quart bottles of fluid, to make double sure that there was not any contamination i the lines and such. So brings me to my question... Bad master? bad prop valve? where did the fluid go to? and help?
