Ford 5R55E Auxiliary Transmission Filter
northern Alabama
2001 Ford Ranger XLT 4.0L with 5-speed 5R55E transmission with 150k miles
I want to add an auxiliary filter kit per Ford TSB-00-23-10 with p/n XC3Z-7B155-G (used to be XC3Z-7B155-AA). Does anyone have the instructions that come with this kit? The replacement filter p/n is XC3Z-7B155-G which replaces XC3Z-7B155-BA.
Thank you.
Curious... is this a super-tight filter media set-up operated as a bypass filter? Does it pull a minute bit of flow off the line to the cooler and bypass it back to the line from the cooler?
It's just a Magnafine or Filtran inline filter.
[Linked Image from cimg7.ibsrv.net]
No, it is full flow.
Doing a search for " transmission filter magnefine " will get all kinds of info for you
Thx. What I really prefer, though, is a bypass filter set-up. The filter media is super-tight, and believe it or not, in no time flat ALL of the transmission fluid gets filtered down to really, really low micron values. The in-line filtlers have to be fairly coarse media, because if they plug off, then you can lose bearings and lube-points that the cooler flow is ultimately directed-to... let alone lose your cooling, too.
Cheers.
