Originally Posted by ka9mnx
Pulled transmission with 125k miles and unknown history. Fill with SuperTech Mercon V and run for 100 miles or so. Drain fluid. If it comes out nice and red and smell ok, refill with Mercon V. If not repeat. Mervon V is a hard spec to meet and is usually full or part synthetic. SuperTech would be my choice (or whatever is cheaper) for that vehicle.
Transfer case. Mercon was the original spec but is no longer available. Ford DOES NOT want Mercon V in the transfer case. I went online and purchased the MotorCraft transfer case fluid (XL-12).
Thanks for the replies. I ended up following your advice ka9mnx and flushed with Mercon V. The viscosity of Mercon V is so different from Maxlife that I didn't want to steer that far from manufacturer's specs. Auto Zone has the Castrol Transmax on 2 for $10 sale, so I picked up a bunch of that. Drained it after 100 miles and replaced the filter, cleaned the pan and magnet, and replaced the pan with the Dorman drain plug version, along with a new Needaparts drain plug, since the one that comes with the Dorman is powder-coated and doesn't seal well. The 100-mile fluid drained out red but still a little dark, so I pumped out and replaced about 8 more quarts.
The new transmission is shifting smooth and working great. Although it was a really hard job and took me over a week, I'm very happy with the outcome, and for $140 pick-n-pull transmission, totally worth it.
I wound up putting Castrol Transmax Dex/Merc in the transfer case. The original Mercon fluid drained clean and red and smelled fine at 177k, so it did it's job fine. No reason to deviate from that either.
