The drivetrain in my 1956 Massey tractor calls for SAE 80 gear oil in the winter, SAE 90 in the summer. I recently changed out all 8 gallons! with fresh GL-5 80W-90 (SuperTech conventional).
This fluid takes care of the transmission, rear differential and PTO (power take off) as well as being used for the internal hydraulic lift system. Works hard for a living
When checking the fluid level after a short test run I see lots of little air bubbles, which strikes me as a bad thing. Air does not make a good lubricant.
The shop manual makes no mention of any special requirements, but I am wondering if I need some anti-foaming additive or some such.
Any advice for me?
TIA,
John
Any advice for me?
TIA,
John
