FM's & PCMO's in Shared Sumps -- Real Experiences
Technically speaking a wet clutch in good working order is not about
to slip no matter what oil the owner selects... what is confusing the
issue is the fact that all motorcycle wet clutches will reach a point
in their life and start to slip... have you notice that no one
complains about clutch slip when new... its about the 27K to 57K range
that contaminants build up to point where the clutch may begin to
loose its grip most noted during a WFO (Wide Fooking Open)throttle
burst... in error the oil could be blamed but technically speaking its
really the condition of the clutch plates...
Originally Posted By: Phishin
Would the higher levels of FM's (found in M1 MX4T)
Who said it has higher levels of FMs?
Quattro....I'm trying to kneed answers and logic out of folks.....if it's not FM's...then what is it?
Someone tell me what makes MC oil "special"? What is it about MC oil that make their bike run better or shift better? I want to know!!!!!!
Originally Posted By: 02SE
Well, granted, I don't spend a lot of time on this site. But the two oils I was thinking of specifically were Mobil 1 High Mileage 10w40 PCMO, and Mobil 1 MX4T 10w40 M/C specific oil.
The values I've seen on this site, were 1600 ppm phos, 1700 ppm zinc in the Mobil 1 10w40 MX4T variant.
867 ppm for phos, 996 ppm for zinc in the Mobil 1 10w40 HM PCMO version.
From what I see, the Mobil 1 10w40 4T oil hlas 1050-1100 ppm Zinc:
https://bobistheoilguy.com/forums/ubbthreads.php/topics/3244217/Mobil_1_Racing_4T_10W40,_Suzuk#Post3244217
https://bobistheoilguy.com/forums/ubbthreads.php/topics/3186938/Mobil_1_Racing_4T_10W40_-'12_S#Post3186938
And from what I can see, Mobil 1 10w40 HM has 1000ppm of Zinc:
https://bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=2330033
https://bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=1883932
So the difference between Mobil 1 10w40 HM and Mobil 1 10w40 4T is a whopping 50-100 ppm of Zinc.....Is that small difference in Zinc responsible for your better shifting quality for a longer period of time?
Even Mobil 1 20w50 V Twin only has about 1200 ppm Zinc:
http://www.svtperformance.com/forums/svt...s-included.html
And you got the answer right sunrah, "because there is a picture of a motorcycle on the label."
well i've been here for a decade+ longer than you.
and my signature is because of the vast number of used oil analysis i've done.
the sole reason i started doing used oil analysis was because of this new motor yamaha came out with in 2001. along the way the used oil analysis provided the data to show that *most* of the marketing hype was bovine exhaust.
I'm using 15w40 Delo right now in m y Harley. There is no ticking or any other noise over the 20W-50 Castrol full Synthetic V-twin oil I had in the bike before. I plan to change it more frequently, like every 2500 miles, then change the filter @ 5,000.
It is about FM. I was just saying there is no reason to believe M1 MX4T has higher levels of FM. Your post made it sound like you assumed that M1 MX4T has higher levels of FM. Zinc, phosphorus mentioned earlier are not FM. They are ZDDP.
As long as you stay away from oils clearly marked as "energy conserving", it shouldn't really matter if the oil you use is marketed as motorcycle-specific or not. That's just my opinion.
I was looking at threads on this site yesterday, that listed the zddp exactly as I stated for the two oils. You can go searching for them if you want, but I have better things to do with my time.
Oil formulations have been shown to change over time, usually with less zddp in each successive reformulation. However zddp isn't I believe considered to be a FM anyway. I was only listing differences, that I noticed between PCMO and M/C oil from the same manufacturer in the same viscosity.
It's also my understanding that the Mobil 1 M/C oil has become less robust over time. So it wouldn't surprise me at all if it's now not much different in formulation from the PCMO version. Bikes now come with catalytic convertors, so they can't have high zddp oils potentially poisoning those catalytic convertors.
I wasn't that impressed with either Mobil 1 version in my bike anyway. I've found and use a M/C specific oil(complete with a bike on the label
) that performs much better, and for more miles.
So, here is my question:
Has anyone had a problem with their shared-sump bike running PCMO's with a high level of FM's?
I'm looking for real world experiences. Has anyone put non-motorcycle Redline (an oil loaded with FM's) in their Harley or crotch rocket for exmaple, and have the clutch begin to slip or behave poorly?
I was just curious. I have never heard or seen of anyone getting clutch problems in their bikes running non-motorcycle oil. Perhaps it's possible. I don't know.
While I initially didn't want to post to this thread because the question at hand seemed like a loaded topic, after seeing the information here I felt some of the stats used here needed serious correction.
While I do applaud you (Phishin) in trying to show members that there are other high quality options out there instead of Motorcycle Specific motor oil like Rotella, Delo, Delvac, etc. HDEO's are much more similar in viscosity and additive packs than standard PCMO's. For instance, you asked is there or what are the differences between a standard Valvoline PCMO and their Motorcycle Specific oil, and there are definitely differences that have been misleading on this topic.
For one, the figures you posted of 1200 PPM of Zinc for Mobil 1 20W50 through the SVTperformance forums was for Amsoil High Performance, not for Mobil 1 20W50 V-Twin. If you are comparing a high mileage PCMO to a motorcycle oil then yes the zinc/phosphorus content will generally be more similar to M/C specific oil. Otherwise, if the oil is the same viscosity comparing a conventional PCMO vs a M/C oil, there are more dramatic differences (see my Valvoline explanation below). For instance, Mobil M/C 10W40 contains 1200 PPM of phosphorus and 1300 PPM of Zinc, while the Mobil M/C 20W50 you quoted at having 1200 actually has 1750 PPM of zinc and 1600 PPM of phosphorus, which is significantly higher than the Amsoil you quoted or a standard PCMO you can buy off the shelves. The link below is from Mobil's website on all their product data sheets showing the same data.
http://www.mobiloil.com/USA-English/MotorOil/Files/Mobil_1_Product_Guide.pdf
Secondly, all the Virgin stats on the two oils can be obtained through their product information PDF's. Here is a direct comparison between Valvoline Premium PCMO and their motorcycle specific oil in a 20W50:
Val. Premium: TBN: 7.3, Noack Volatility %:
Val. M/C: TBN: 8, Noack Volatility %: 7.3%, Zinc: 1120, Phosphorus: 1030, Calcium: 1820, Sodium: 520
As is blatantly obvious MC is better in every spectrum. TBN is higher, the Noack volatility percentage loss (loss of oil at high temperatures) was TWICE AS MUCH in the premium than the M/C, Zinc and Phosphorus levels were nearly 40% higher, and Calcium/Sodium were also higher. So YES, there are major differences between these oils just in Noack % and the additive pack alone. Furthermore, the M/C oil will be utilizing different forms of viscosity index improvers to reduce shear, and will also be reducing/lacking friction modifiers to comply with the JASO MA spec. Additionally, just because an oil's viscosity lies outside the API SN specs of 0W20-10W30 does not automatically mean their phosphorus/zinc content goes up as shown here.
To further distinguish the two, the Motorcycle Specific oil is actually CHEAPER than the Valvoline Premium oil! My local Walmart sells the Premium for $4.58 per quart, and the Motorcycle Specific oil for $3.98 per quart, so yes, I would HIGHLY recommend the use of the motorcycle specific over the standard PCMO, not only for the cost savings, but for a much better oil that also meets JASO MA standards.
Here are the references to back them up:
http://www.valvoline.com/pdf/premium_conventional.pdf
http://www.valvoline.com/pdf/4_stroke_motorcycle.pdf
Now that we have conclusively established the difference between Motorcycle Specific oil and a standard PCMO, the answer to your question as to whether or not anyone has had adverse reactions in a shared sump motorcycle, the answer is yes. While I personally have not had an issue (I've nearly always used a JASO MA oil), I know of good friends that have had issues using standard PCMO's in their bikes ranging from big V-Twins to a Honda CBR600 F4I, and I've also talked to fellow riders that don't have any issue at all using them. While I do agree with Quattro Pete that it's much better to stay away from Energy Conserving Oils, I also agree that a large portion of any clutch issues are generally related more to clutch wear, contaminants and glazing, clutch springs, or other issues as BusyLittleShop stated.
Now to get to the technical stuff. JASO (Japanese Automotive Standards Organization) was formed back in April of 1996 due to the fact that there were no domestic quality standards for motorcycle oil. They initiated the organization because of three main oil related issues they were encountering by not having a motorcycle specific standard: 1. Lower Viscosity Oils 2. Effects of oil shearing 3. Improper clutch activation.
To put it simply, the Lower viscosity oils were providing improper protection due to a lack of oil film strength, causing their main issue in problem #1 which is generating increased wear/pitting throughout the gear assembly. Secondly, the effects of oil shearing led to improper protection including a lack of oil film strength which necessitated the use of different/stronger VII's. Thirdly, clutch activation was suffering due to slippage and not being properly engaged. The results of using PCMO's back in the 90's led to these issues (which would be more exaggerated in now a day PCMO's) and these issues are, and I quote that "These field problems have actually been observed that are probably attributed to such problems."
The use of a JASO MA or above (MA1, MA2) provide you wish these solutions to these problems, especially in regards to the clutch related issue you brought up by having to meet the Dynamic Friction test (related to clutch feel/take up, Static Friction test (relating to clutch slip), and Stop Time Index (relating synchronization time) thus making them more suitable for motorcycle applications than standard API designations along with other standards including: evaporative loss %, foaming tendency, shear stability, and high temperature high shear viscosity that are more strict than standard API designations.
http://www.jalos.or.jp/onfile/pdf/4T_EV0604.pdf
The Chemistry and Technology of Lubricants by Roy M. Mortier (Editor), Malcolm F. Fox (Editor), Stefan T. Orszulik (Editor) 2010
SAE Automotive Lubricants Reference Book by Roger F. Haycock and Arthur J. Caines 1996
So, to turn this giant post (and yes I'm sorry about the length) into something concise, I'll say this. PCMO's that are high mileage and HDEO's generally have similar additive packs to M/C specific oils, but there are serious differences between PCMO and JASO MA rated oils and that their chemistry's can be different (FM's, VII's, etc.). Does this mean "I'm in bed with JASO"? Absolutely not! I run Rotella 15W40 in both my Yamaha's (even though under their specs it qualifies for JASO MA) and balk at paying even the cheapest price I've found for Mobil 1 10W40 at Walmart for $9.99 per quart (which they indeed are ripping individuals off that purchase it). I believe we can all thank and appreciate Sunruh's used oil analysis which show that "*Most*" of the hype behind the oils is indeed just that, and I once again applaud Phishin for showing that you can find great oil out there for a fraction of the cost of some motorcycle specific oils, but to state their is no difference between them is simply incorrect. Again, these standards were created in Japan by their automotive standards organization to keep their motorcycles running properly and efficiently, they weren't invented by Mobil and Castrol to make more money, they just didn't want the motorcycle brand name oils like Yamalube to be the only recipients of motorcycle oil profit, but in doing so, they've gotten greedy and decided to charge more than they should. I've spent far too much time in this post, so I probably won't respond back unless it's something serious/pertinent, but these are the facts backed up by science with respectable references, to agree/disagree is just fine, but the facts remain the same.
Analyzer....THANK YOU!!
I had a hunch that some PCMO's might not be best or even problematic for some bikes, but I had no idea why. All I ever heard was speculation. Now I have the facts.
That might be on of the best posts I've ever read on BITOG.
Yes, I was playing Devil's Advocate. But at the same time, I did't have the answers. You made it crystal clear. Bravo.
Thanks guys! No worries Phishin, I figured you were playing Devils Advocate and I think it was a good way to draw people into this commonly questioned topic, it sure reeled me in...accompanied by an "essay" lol
The redline car oil is loaded with moly(like 700ppm), the motorcycle ma type is not(but there's also an MB rated mc type (vtwin), I did develop slippage issues with the redline car oil after a few thousand miles of use on a motorcycle. Swapped back to a known good clutch oil rotella 5w40 and no more problem.
but there are a lot of car oils that don't cause issue, but there are some that do.
you actually have to *search* for one that will. like the redline car oil with 700ppm moly. i really doubt you can find anything at a Walmart/autozone/advanced/oreily/... that would be anywhere near this. sure, a single store in your area might have it, but not nation wide. (ex is Pennzoil Ultra at walmart...some have it some dont).
i've yet to test anything over 135.
700 is way up there!
Just want to say Thank you for your excellent post. As I have a new Ducati streetfighter that I just did the first oil change on at 900 miles. I used the valvoline M/C spec 4T oil. I will sleep better at nite because of your post. Even though I had no intention of using anything other than M/C oil. Thanks again keep up the good work.
I have been able to always get MC specific oil on sale for about $8/quart and some even less. So when I find it cheap I simply buy 3-4 years supply.
This was all very general. Cycleman, you care to explain what this means:
Originally Posted By: cycleman
If you check out the specs for a motorcycle oil with either the JASO MA or JASO MA2 endorsement you'll see that the big difference is going to be in the friction needs of the wet clutch. Both of these two specs have a different level of friction additives by percentage at the lower end but the same amount at the upper end.
What are you referring to? You mention different FM's levels at "lower end" and "upper end". Give it to me in plain english if you can.
1.) What FM's are you referring to?
2.) What limits are you referring to?
And in my original post, I basically asked: Has anyone ever had any clutch issues running non-MC oil in their shared sump or wet clutch bikes?
I'd like some specifics if you can give them. When I read your response it reminded me of the answer that Bill Clinton gave when asked about Monica Lewinsky.
Some of what you are asking for has already been answered under Analyzers post, but if you query JASO MA or JASO MA2 you should come up with the pdfs put out by the Japanese JASO organization. They show the percentages and also the allowable limits for zinc etc.
