Quote:
We do install inline filters and the one supplied by site sponsor Magnafine (spelling?) works well.
How often do you guys change those out?
Quote:
One method worth consideration for many is to drain what you can (or suck it out) and refill. Do this every 15-30k. We use this in fleet service and have stopped flushing except when problems are encountered with a given transmission. With over 10 years and a lot of vehicles we can not tell, looking at the data, the difference between the drain and refill (15-30k) method vs. complete flushing (usually 60k).
Quote:
Quote:
I have read (myth?) that on a few particular models, the position of the transmission shifter is important when using the cooler line method, i.e., park, drive, or neutral.
I had both a Jeep Grand Cherokee (01) and an 03 Dakota, both with 42RE chrysler trans and they did not pump in PARK. Manual even said to leave in neutral to check fluid level. Have an 06 Dakota now with 42RLE w/ some kind of variable pressure thingie and it can be checked in park.
However , I think there are more chrysler trans than just the 42re that would not pump in park. just FYI.
Can anyone elaborate?
Thanks
Allegedly, some cooler flows are blocked in PARK. I've never encountered it ..but a trans rebuild guy once remarked about a mid 90's Ford OD trans having this feature/characteristic.
..but as SteveS says, you'll find out. If PARK doesn't do it ..NEUTRAL should.
Quote:
so at any point in time fluid that is hot is not always being pumped to the cooler to cool?? meaning it stays up in the trans?
Quote:
Don't ignore all the lubrication, cooling, VB circuits throughout the transmission, and any ATF working points. ATF flow is NOT a perfect loop.
The mixing of old and new is in the pan, throughout the transmission, and in the TC, constantly.
Take a glass(your ATF pan) filled to the brim with milk. And, slowly pour three equivalent glasses of water into the milk(collect the overflow).
This is how 'each' point in the transmission mixes old and new ATF.
Your cup of milk is now and diluted foggy water/milk mixture. Quit dreaming that ATF flow is a perfect loop.
Now, take the 3 glasses water/milk mixture that overflowed from the original milk filled glass, and use it to 'flush' another glass of milk(your TC). Repeat for VB, repeat for ATF cooler......
