I did my antifreeze drain and flush last year (using distilled water of course) but I just ran across the mityvac website where it says that you should use a vaccuum system when you drain and fill your antifreeze because you get air bubble trapped in the system and it makes hot spots. When I did mine, I figured the water pump should pretty much circulate the air and fluid through the system anyway and I can just top off after a few days. Is there any potential harm in doing it the way I did versus using a vaccuum bleeder (that they sell)
