While repairing the gear shift lever of the non-synchronized manual transmission on our old IH tractor, I was able to look inside - it did not look good with all the sludge/varnish on the housing. And of course it has larger wear particles floating around at the bottom. This tractor has a seperate hydraulic oil tank and will commonly use regular GL-4 or GL-5 gear oils in the MT.
How can we clean this mess out before we get us some new gear oil inside?
I was thinking about draining out the current oil, refilling or even overfilling with some used THF (5w30) and 10 or so percent gasoline or diesel. What will happen if we leave it in there for 5-10 operating hours, without working the tractor too hard?
