Originally Posted By: Big Jim
You need to total fill quantity and possibly plus a little. Unless the current fluid is in really bad condition, I doubt that you need 50% more.
If you are doing the hose in a bucket flush from the trans cooler lines, you flush until the fluid coming out is as pristine as the fluid going in. Usually that is at the maximum capacity or a quart more.
Really? I was told that because the fluid mixes during the exchange process, you need a lot more than the unit's capacity for a complete fluid exchange.
Clore Automotive, makers of the T-Tech, state on their website that 20% over the unit's capacity is recommended. Some technicians have told me that twice the unit's capacity is needed if you really want a full flush.
Although this wasn't recommended for transmissions, GM recommends exchanging 50% more than the system's capacity in regards to coolant exchanges if you use a coolant exchange machine.
