I have seven fluorescent light fixtures in my cellar on the same circuit, each holding two 48" T12 fluorescent bulbs. Three of the fixtures work consistently, but four of them are not working properly, that is, they come on when they want to. One fixture will eventually come on if I flick the light switch on and off enough times. The other three would not come on at all, or sometime just one bulb would come on weakly.
I replaced all of the fluorescent bulbs in these four fixtures and there is some improvement but not much. The one that came on eventually with switch flicking behaves the same. The three that would not come on at all now will light randomly. As I flick the light switch on and off repeatedly, sometimes all three will come on, sometimes none come on, , and sometimes one or two will come on randomly. When they do light, both bulbs will light and they are bright.
These fixtures are hard wired and are likely as old as the house, 28 years. Is this a ballast issue? If so, are ballasts reasonably easy to replace without taking the fixture down. I know I should replace them all with LED fixtures, but I don't use these lights often and am looking for an easy fix.
