Alright guys..im just trying to get some opinions on what trans fluid to use. I blew the transmission in my Z28..I ordered a Level 1 4l60e from performabuilt. All they recommend is a fluid that meets or exceeds Dex III specs. This transmission will also have a 3K stall converter, and i will be running an external cooler as well. My concern is with that 3K stall converter i will be generating a good amount of heat. This car is my daily driver, and i am living in orlando florida where its crazy hot. Im kinda torn if i should use a full synthetic or not..Either way i will be doing partial fluid changes roughly every 15-20K miles. The only good thing is that whatever fluid i use i will have 100% of only that fluid in there..So if i do use a full synthetic, i wont have to worry about having it diluted with old fluid or anything. I have been thinking of using Amsoil or Mobil full syn. fluid if i go that route. If i use conventional i was thinking of just valvoline or pennzoil..So i dont know..give me some advice on what you guys would use? im open for any suggestions.
-Travis
PS- i forgot to add that the car will occasionally see the drag strip for some racing.
-Travis
