M1 75w-90 is a GL-5 fluid. Double check again what your trans calls for. If it specifically calls for GL-4 (like my old 2001 Audi did), then I would not use a GL-5 fluid in it. The EP additives in GL-5 fluid are said to negatively affect brass synchros in the trans.
Originally Posted By: rfeir
I was thinking of using Mobil 1 75W-90.
It is a GL-5 fluid.
A customer on the Mobil.com site asked a question about using M1 75w-90 GL-5 in their Audi manual trans and Mobil specifically stated that it should NOT be used in that application. As a GL-4 fluid is required.
