gathermewool
Site Donor 2025
97 Subaru Legacy GT with 206kmi (owned since 167kmi)
Reman’d alternator, but not sure when or by who. Looks pretty new (compared to the rest of the engine compartment) but that may not mean anything when it comes to quality or age.
About a year ago I bought a scangaugeII. I didn't always have it on Voltage until recently, but never noticed anything less than 13.8 V on the highway and 13.4 at idle, even when loaded.
I was flipping through the gauges and noticed, with the headlights, radio and heater on, that the voltage was reading around 12.6 at idle. After some monitoring, I noticed it would regularly go down to the mid-to-low 12's loaded at idle (low 13s unloaded) and low to mid 13s at highway RPMs. It would even go below 12V on occasion, though that was only for an instant before popping up.
After a quick look I noticed the insulation to the connector had crumbled away about six inches, leaving exposed, corroded-looking conductor. I had an electrician buddy of mine replace about two feet of wire that had brown, over-heated insulation with new stuff. The wiring past where it ran over the engine looked good all the way to the fuse box.
I noticed an immediate improvement, but it’s not where it used to be. I’m getting a fluctuating voltage on the highway from 13.4-13.9V regardless of load, and anywhere from 12.8-13.3V idling, varying with load. I’ve seen as low as 12.4 still, with the lights on and A/C on high.
It may be coincidence, but the problem seems to be worse when it rains.
Also, the RPMs at idle when this occur stay very steady at 650.
Is low voltage or varying voltage a definite sign of a failing alternator or could it be caused by a small ground?
