I have read alot about flow on this board, some real good stuff. As the different filters are discussed here regarding flow and lack of it on some, I was wondering, what about the engines requirements? Should't that play into consideration? Don't different engines have different flow rate requirements? Don't you really need to know what the max flow rate is on your vehicle? I want the best filtration possible, and if my truck doesn't require a 5+ (example) gpm filter then wouldn't you be better off with a filter that can accomidate that and give the most filtration? I am thinking from the reading here, that you are better off to find what is the max flow needed, and then look for a filter. Be easy on me guys, I'm a raw rookie, Larry
