Fleet Engine Oil Question
FL
I manage a fleet of 40 vehicles but started with this same company as a tech 10 years ago. Since before I started here through today, our shop has always purchased Mobil Delvac 1300 Super 15w40 for our entire fleet. Until recently it was a mixed bag of gas and diesel engines from 3.6 Rams to Cummins ISB 6.7's and Cat C7's. Today, the fleet is mostly gasser Fords. 2015 and newer 3.5L's (NA), 5.4/6.8L's (2V), and recently a handful of 7.3's (still have a couple 3.6 Chrysler engines though). I've been going back and forth on changing our bulk oil purchases from the Delvac 15w40 to a 5w30 synthetic blend to be more in line with Ford's "manufacturer recommendations" and maybe improve the fleet's MPG's in the process.
FWIW, I haven't had any issues with the 15w40 in any of our vehicles, and we keep them until 200k with a 6k OCI. We're in Central Florida and these vehicles do mostly highway speeds and some moderate idling.
Wanted to gather opinions from the BITOG crowd, as most posters seem to have done a lot of research and are well knowledged in the engine lubrication world. Do you think the move to 5w30 is wise, or should I stick with the "if it's not broke don't fix it" approach with the 15w40?
Moderate fleet idle is still a lot and idling is harder on the engine than people think as hths and heat become an issue. Both of which 15w40 will do better than 5w30 though using 5w30 in all your gas engines wouldn't be bad it's not better than 15w40. A cheap syn blend 15w40 is better formulated overall than a cheap syn blend 5w30 Keep using 15w40. Hot weather and idling makes it a better choice.
Have you ever considered trying a 5w40? It might not meet your cost requirements but I would think it would be a great "middle ground" for all of your vehicles.
