Fired up my 65 mustang!!!! help w/ vibration
So Cal
For those of you that know of my stang restoration. Well, its running. Have to rejet the carb. its way fat... Timing is dead on. Adjusted valves. Still have a vibraton @ 2000 rpms. Havnt put it on the road yet.
Is it normal to have some vibration untill the rings seat? ton of blowby. enough to push the dipstick out from the pressure. had to install a pcv LOL..
when the motor was built it was blueprinted and balanced. just lookin for a little guidance ...
I assume you checked this frank...but how do the motormounts look? If their loose or damaged, you'll get all sorts of crazy NVH.
Of course if you went to solid mounts, that would explain things too
Make sure the Balancer and Flywheel/Flexplate match the crfakshaft you have. If the engine was balanced you may want to question the builder about which balance factor he used and if it matches your components.
A miss caused by the mixture and/or timing can also appear to be a vibration.
If the cam is a bit on the warm side it may not be fully on the cam at 2000 rpm resulting in the vibration.
PS High Performance engines are sometimes "Overbalanced" for high rpm operation. This can reduce smoothness at low rpm.
Gene
Gene,
Elaborate please. I'll check and make sure flywheel balance matches damper etc....I added a pcv and cured the dipstick jumping. Motor mounts are brand new...my mech said that we needed to jet the carb down quite a bit.
Man I hope I don't have to pull this motor out. Just the thought of that makes me cringe..
Originally posted by Not the Autorx Frank:
pcv cured the problem. it was pcv less when we fired it. still gettin a little blue smoke but nothin scary.
I'd still do the compression test, a dipstick blowing out without the pvc hooked up is still not right.
You posted that it was rebuilt, rings could have been broken on install, it happens.
Gene,
If you used a hotter cam ie Hi-Po 289 or Aftermarket you may still get some reversion at a rpm beyond which you can discern any lope. You may still feel it as a vibration.
Nice to hear you got it fixed.
Gene
Frank, I'm sure you're aware that there's two different firing orders for the 289/302, depending on the cam used. I doubt if it would even start if the firing order was off, though.
There's also two different weights for the harmonic balancer, but then I can't imagine an engine shop making a mistake with this either.....
Might be the compression blowing out the spark on a faulty plug, at a higher rpm.....you could check them with an ohmmeter; the resistance measured from the connector to tip should be around 5K-6K ohms. Wires should be about 5K-8K ohms per inch.
I'd double check the simple things first.
Thanks guys for all the chiming in. I have a good punch list now. I will re check all the obvious too..
I really appreciate everyone taking the time to guide me.
I'll be back when this is sorted out and let yall know what it was.
It is 302 /351W that has the different firing orders
IMO, something isn't right. Over the years working with dozens of rebuilt engines I've never seen one that was put together correctly that had excessive blowby from the first time it was started. Once the assembly lube was burned out they didn't smoke either. A few minutes running and it should be burning clean and you shouldn't see much of anything out the breather, even with no pcv valve...
ok an update.....
had a leakdown and compression test done..... everything checks out ok. went in and re-adjusted valves after getting it good and warm. smoothed it out some... the vibe is not violent at all just a little jitter around 2000 rpms. dead smooth at idle and higher rpms. still gotta jet the carb down a bit. all in all getting better. I think Gene may have been on to something with his comment.
"reversion at a rpm beyond which you can discern any lope. You may still feel it as a vibration. "
I'll let you guys know how it does under a load when i put it on the road after we jet the carb and align it.
thx again everyone!!!!!
This is true for stock engines. However many cam manufacturers go to the "later" firing order for the 289/early 302, to promote engine longevity and smoothness.
The 15426378 order tends to hammer out the front main of the 289, because both front cylinders fire sequentially. The 13726548 order is much better. Makes me wonder why Ford didn't figure this out sooner.....?
yeah i get ya...this has the standard 302 order...i know most roller cams use 351 order but this one keeps standard order....
I'm learnin a bunch through this project.
