Originally Posted By: JohnBrowning
So it is not a thick or thin it is a matter of what is working best for you in your application.
Loads of used oil analysis posted on S2ki (one of the S2000 forums - or should I say fora) have shown low wear with xxW-30 oils, even when it also showed the conventional oils had sheared down into 20 weight range.
So, in this application, history shows a 30 weight is working pretty good.
Some of us do not mind running an oil with an HTHS that is marginal and right on the line some people need a bigger cushion for their own sense of well being or because they drive their car like they just stole it!
You're talking like a guy that likes the oil to be thick for "protection".
Get over it!
There was a used oil analysis posted not that long ago on S2ki, M1 for 4900 miles including 2 track days and the ppm's were low.
Sure, a little (5ppm) higher than universal average, but that's nothing keeping the 2 track drive-it-lile-you-stole-it days in mind.
My personal experiences with a 40 weight (Shell Helix Ultra 0W-40) were ok, used oil analysis showed iron ppm to be 3.73/1000 miles.
Oil was used for 67xx miles.
After that I used 0W-30, iron ppm was 1.88/1000 miles.
Oil was used for 12xxx miles, including 1 track day.
I'm all for true syn 30 weights in this engine!
Ohh.. and I would like to add that IMO about half the posts here are about
So: get used to it!
