I have a couple of Classics, which I try to flush/bleed yearly. As others have mentioned, DOT 3&4 is hydroscopic and readily absorbs moisture.
That’s actually GOOD, assuming you regularly flush/bleed your brakes. That way you won’t have any corrosion within. It’s bad though if you never touch the system and let the moisture build up
I still prefer to flush and bleed the Old Fashioned Way, it helps the neighbor kid likes to work on cars. The vehicles I drive daily, I’ll flush/bleed after the first year of use, then every 2 years, max.
