I bought a new Chevy Silverado 5.3L truck. I've baby'd it for 1,150 miles now and need to start thinking about it's first oil change. I think anywhere between 1k and 1.5k is fine to dump the original oil and filter. (Lets not argue about that) Some people think you should do the first oil change with dino oil and then go to synthetic but I'm thinking I'll just make the switch to synthetic with the first oil change and then change it every 5000 or 6000 miles, at the same time I rotate the tires (it's convenient to do both at the same time).
I know from this forum that Supertech has the best filters (been using them for a couple of years now) but are these ok for synthetic oil? I was going to use Mobil 1 for the oil, should I use a Mobil filter or use the Supertech filter? In other words can an everyday dino filter like the highly rated Supertech be great for dino oil but bad for synthetic oils? Do I need to worry about it?
Thanks BITOG members,
Jeff
Jeff
