Do filter bypass valves open when you start a cold engine? Not necessarily a winter start, but when started in the morning when the oil is at its thickest for the day. If so, since bypass' are set by psi and thicker oil increases psi, would a cold 5W-20 not open the bypass where a 5W-30 would at the same temperature?
