I'm having a [censored] of a time trying to share files between W7 and Vista!! Royal PITA....
Problem #1:
I'm unable to change the name of the WORKGROUP Vista assigned; it's grayed out. The W7 machine is on a different workgroup and I want Vista to use it.
Problem #2:
Not sure if the WORKSTATION service has anything to do with this, but I'm unable to start it. I get the error msg #1079 "the account spec'd for this service is different from the account spec'd for other services running in the same process."
Problem #3:
In Vista, file sharing is stuck on CUSTOM rather than ON and I'm unable to change/affect/modify it. It immediately reverts upon any attempt to do so.
My purpose is to use the largely free disk space on the Alien LT HD to store the old files from WXP HD mentioned above, so I can wipe it, the clone the failing W7 drive to WXP. However, #$%^! Vista refuses to allow me to make the necessary changes and is being most uncooperative!
Please Advise!
TIA...
Problem #1:
Problem #2:
Problem #3:
Please Advise!
TIA...
