Popsy
![crackmeup2.gif](https://bobistheoilguy.com/forums/graemlins/crackmeup2.gif)
Actually today thing are worse, I noticed that if I take the car (cold), then run at low rpm (to enjoy the massive torque of this powerful diesel at low rpm, lol), some highway still at relatively low rpm for a long time, there is noise from diff/gearbow when reversing, or even when changing down from third to second gear (that is new).
But if I take the car (cold), then push it (when motor is warm) at higher rpm, do frequent change down or up (like driving in traffic, this thing is slow as [censored] so to maintain in traffic you have to push it a bit), then the noise is gone, even when reversing.
Could it be the higher rpm cause more "oil splashing" in the gearbow, which helps reducing the noise? On some Fiat forum, they advise to raise the car so you can put more oil in the gearbox, good advice?
Anyway, I'm going to live with the noise and call it a day, replacing gearbox isn't that difficult on this model.
