Facts about oil consumption
Glad you found it useful, ADFD1! You're welcome!
I'm using a quart every 2 thousand, BMW X5 93,000 miles. I was worried but, here It sounds like as long as I keep up the 7500 mile synthetic changes. I might just get 250,000 miles out of this engine. I hope so, I really like this car.
Originally Posted By: lexus114
Originally Posted By: KrisZ
Quote:
One of the most important points in proper vehicle maintenance is to keep the engine oil at the optimum level so that oil function will not be impaired. Therefore, it is essential that the oil level be checked regularly. Lexus recommends that the oil level be checked every time you refuel the vehicle.
I think this part is really important, and a lot of people ignore it.
I had a friend that used to brag that his car only gets the best synthetics (Royal Purple) and when I asked how often he changes his oil, his reply was, when the little oil light comes on (he was talking about the oil pressure idiot light).
Uh,thats a little over kill isnt it??
I also think that checking oil every fillup is excessive (I do it about once a month) but manufacturers try to tag this stuff to something that is performed regurarly, so every fillup seems ligical.
Originally Posted By: ryland
My friend who has a rx-8 only will use conventional in his rx-8 and other cars because mazda says according to him that the rotary engine meters a small amound of oil with each revolution (much like a two stroke but at smaller incriments) and that synthetic oil since its designed to resist burnoff leaves a residue when burned and that conventional burns much cleaner. So just like this says normal piston engines burns small amounts as well so he refuses to use synthetic. While I dont agree with him thats an intristing theory.
If this is true, i mean, when synthetic oils are burned up, it leaves a residue that's worse than conventional oils, then we should be thinking about the following:
I have a car that burns oil (over 100K miles)1/2 qt per 2000 miles. Would I be better off using conventional oil since it burns faster than syn oil? I really don't want residue of burnt syn oil accumulate inside the combustion chamber and on piston. I need to think about it now. Maybe syn oil does have a neglected disadvantage. what do you guys think?
