F-150 5.0, Mobil 1 5W-20, 7k miles
Houston, TX
Diagnosis: All wear levels appear within acceptable limits for first sample. Silicon level (dirt/sealant material) satisfactory. Water content acceptable. Viscosity within specified operating range.
Action: As oil already changed, resample at next recommended interval to monitor and establish wear trend.
Code:
DATE SAMPLED 06-Nov-15
DATE RECEIVED 19-Nov-15
DATE REPORTED 23-Nov-15
TIME ON UNIT 27127
TIME ON OIL 7004
OIL BRAND Mobil
OIL TYPE Mobil 1
OIL GRADE SAE 5W20
OIL ADDED None
FILTER Changed
OIL CHANGED Changed
Metals (ppm)
Iron (Fe) 10
Chromium (Cr) 1
Lead (Pb)
Copper (Cu) 2
Tin (Sn)
Aluminium (Al) 3
Nickel (Ni) 1
Silver (Ag)
Titanium (Ti)
Vanadium (V)
Contaminants (ppm)
Silicon (Si) 14
Sodium (Na) 7
Potassium (K) 1
Additives (ppm)
Magnesium (Mg) 757
Calcium (Ca) 1106
Barium (Ba)
Phosphorus (P) 726
Zinc (Zn) 839
Molybdenum (Mo) 80
Boron (B) 51
Contaminants
Water (%)
Coolant No
Physical Tests
Viscosity (cSt 100C) 8.5
Physical / Chemical
Base Number (mgKOH/g) 5.1
2013 F-150. These were highway miles although they were highway in city of Houston, which has a mixture of highway speeds, traffic jams, sudden accel/decel, etc. During this change I also found that the air filter was loaded with dirt and changed it.
I would continue with the Mobil 1; changing your air filter should help bring the silicon down. I would change it at 5000 miles on the next run and resample, that should bring the iron down a bit.
Mobil 1 is all I use in my Crown Vic. Excellent oil!
Enjoy your Ford F-150 and Happy Thanksgiving!
Originally Posted By: buck91
What was the remaining life on your iolm?
I honestly don't know as I don't pay much attention to it. It is more of a nuisance than a help if you maintain a regular schedule.
Agree on the NapaGold/Wix filters. When compared with the OE filter, it looked to have twice the surface area. I expected to get a full 30K miles out of the OE filter, but it was so loaded up with dirt that it had to be changed. That was another reason for doing the analysis.
I also agree on the M1. Best bang for the buck IMO, been using it in my fleet for last 15 years.
