I have a 3.5" SATA drive in an external enclosure, connected to the PC (Win7 32-bit) using a SATA cable. The enclosure has an ON/OFF switch. The PC will only "see" this drive if the enclosure was ON when the PC was booting up. If I turn the enclosure ON after the PC already booted up, the PC will not see the drive. Is there any way to change it so that I can turn the enclosure ON after the PC has already been started?
FYI, this problem only occurs when using the SATA connection. If I use a USB connection instead, I can turn the enclosure ON at any time and the PC will see it right away.
