How much gas does a V10 Ford use in 6 hours at idle?
That plus 200 miles a day must put you at the pump every single day!
It uses a LOT of fuel idling. Before I picked up this gem,, I was using a Dodge Ram with a 5.9 (360 gas) motor. That truck idled all day on a few occasions and I calculated it out to 3qts of gasoline/hour, which I thought was [censored] good! I picked up this V10 at the end of December and although I haven't calculated the exact consumption at idle, I know it is probably triple of what the 360 was. It is an absolute pig at idle. Driving @ 70 mph, and scaled at 11,100lbs (truck is a dually with 4.30 gears and is only rated for 11,000#GVWR), it gets about 10mpg. All fuel is supplied at work and there is no "meter" on the pump, so I haven't been able to get an exact fuel consumption when idling all day.
Originally Posted By: jorton
If engine speed is a factor in setting viscosity, 5w-20 will be ideal.
Will you be able to keep the same o/c interval after you switch to conventional, or will you have to get a couple more oil changes a year?
Well once the weather warms up comes April, I won't be required to idle it at all, so I'll probably go with 3-4000 mile intervals. I do drive a lot of gravel roads.
