demarpaint
Originally Posted By: Garak
It happened again today. I left the machine for a while, had streaming news running and came back to a bluish/black screen.
I noticed when my Mint/Mate setup goes to shut the monitor down after a period of inactivity, it kind of sits like that, but comes back when I hit the mouse. It's like a period between the OS not sending anything to the screen, but before the monitor shuts itself down because of no signal or because power management tells it to shut down. It sits like that, I move the mouse, then the password screen comes up, and I'm back at my normal screen where I was before that happened.
I'm not the greatest hardware guy, so I'm going to be shooting in the dark a bit, but your problem does seem kind of odd. Basically, you get to that situation, and it won't start displaying again from moving the mouse? Does it still do nothing when you hit a key? The reason I ask is because I cannot wake up my computer with a mouse move, but I can with a key press, and then a mouse move to bring the password unlocker up.
Now, the power management is separate from the screen saver. Try disabling your screen saver and see what happens. My screen saver, just checked it now, is set to go to a blank screen after five minutes. But, the display is put to sleep under power management when inactive for 30 minutes.
Thanks for the reply, to clarify, moving the mouse or hitting anything on the keyboard won't turn the monitor on when the system has one of these episodes. I went almost 4 days w/o an event.
The screen saver is set to off, however I have the monitor sleep after 30 minutes of inactivity. Sleep, hibernate or anything related is turned off.
I might try leaving the monitor on all the time and see what happens. That's next in line. I might also try another monitor again. The reason is because the tweaks that I made that stopped the ghost issue were done after I tried the second monitor. Maybe the monitor is bad? It's easy enough to put the second monitor back on. What's odd is power is going to the monitor, it has the orange light on when this happens, but the light won't turn blue indicating the display is working. Unplugging the monitor fixes that.
The ghost issue has been resolved, so I'm moving slowly in the right direction.
