exhaust rerouting question
Saint Paul (ex-San Diego)
I have a Mk4 Golf TDI that I use almost entirely as a courier vehicle -- so much so that I have removed the front passenger seat. The rear seats are folded flat and they and the hatch area are covered with 1/2" plywood so I can haul more cargo. A lot of my deliveries are electrical, plumbing, HVAC and other parts and supplies for contractors. Generally it works out very well, because if what needs to be transported is more than my Golf can handle, we have other drivers with pickups, vans, and box trucks. I typically drive about 5000 miles a month.
Often I need to haul bundles of 10' PVC pipe, copper or galvanized conduit, or threaded rod. With the front seat removed, I can get about 9' of these pieces inside the vehicle, with about 1' sticking out the back. I use a bungee cord to hold the hatch down, strapping it to the tow bar.
Fumes sometimes get sucked into the cabin, so I have to crank up the fan and lower the front windows. But with winter coming on, I'd prefer to keep those windows up. So my question is, where should I reroute the exhaust pipe to prevent the exhaust fumes from entering the cabin?
My options seem to be 1) to the side, exiting behind the rear wheel, or 2) extending the pipe several inches straight out the back. But which is more likely to work? and if I extend the pipe, how far?
Other than trial and error, how should I determine which option is most likely to work?
Your problem is the air pressure caused by the bubble shape of your car. How air closes around the rear of the car at speed is as important aerodynamically as the front... which is why the "Prius shape" is a thing.
I wonder how hard it would be to modify your hatch so just the glass opens, but the metal frame stays closed. That would be more of a buffer between the interior and the exhaust pipe.
But to answer your question, mess around with the pipe as you're doing. You'll be blasting the heat anyway, on vent. You can get random pipe pieces and clamps for $10 to extend beyond your muffler. They come with a slip fit fitting that'll go over your current exhaust tip. Maybe a good "turn down" will get the smoke into the under-car slip stream instead of the dead eddy it's in now.
The only other idea would be a long tube mounted on the side or roof of your car-- I've seen them for pole vaulters. That would cut into your MPG though.
eljefino, nailed it. There is a low pressure area at the hatch created by air moving over the top of the car. Mythbusters found the same thing with pickup truck tailgates. More drag with the tailgate down than up.
That low pressure area sucks in the exhaust when the hatch/window is open/down. To get exhaust out of the low pressure area, you would need a long pipe, it would look silly, and probably not legal.
Your option really is roof carry, or keep the front windows open with full blast heat/ac.
EDIT; I wonder what the effect of a rear hitch rack would be on the airflow, one of those might work with an attached solid plexi or plywood floor.
Having the exhaust routed straight up to slightly above the cabin like a semi truck would work the best.
Exhaust out the side in FRONT of the rear tire... but a vertical stack like a "deuce and a half" would be best.
You have to get the exhaust out of the boundary layer that surrounds your vehicle at speed. Doesn't matter where you route the exhaust. If it doesn't escape the boundary layer, it's going into the hatch.
Is there a reasonable way to get the exhaust to esxapw the boundary layer? No, there isn't.
I think the best result would be a small pipe exiting to the side. Using the exhaust velocity to push it away from the car's aerodynamics. Piston powered aircraft use the exhaust's directional blast to prevent CO from entering the cabin. However, I don't think that's a complete solution, as at light throttle, exhaust velocity will be lower. In much the same way that piston powered aircraft on descent (with throttle pulled back) often get fumes in the cabin.
I'd go out the side, or the long exhaust above the vehicle.
How about some sort of custom foam fitted to fill the gap?
So you think in front of the rear tire would be better than behind? I could do that, but I'm interested in hearing your reasons.
You might try a scoop that entrains higher pressure air around the exhaust, say a halved traffic cone, or metal equivalent if the exhaust is too hot to be plastic friendly.
Or do a lateral-thinking body swerve around the problem and rig yourself (not your engine) a schnorkel (and a nose clip) so you'll be able to breathe with the car full of fumes (or water).
No need to provide for passengers since there are no available seats.
Turbulent airflow, and the "bow wave" in front of each tire. It's also the easiest way. Make the exit 12"/30 cm in front of the rear tire and make it a good 2-3 inches out past the outside sidewall.
