Originally Posted By: ag_ghost
Not a cracked HEAD, a cracked MANIFOLD. I've never heard of a Windsor cracking a head. But they do like to crack their exhaust manifolds. Often times it is easier (and far less expensive) to just replace them with a set of headers, like the ones I mentioned above.
Huh? I've been around and had Fords of many varieties for > 30 years and have NEVER had or heard of a cracked exhaust manifold. Do we even know if the OP has a V8 Windsor or an in-line six? Don't get me wrong, headers have their place of course, but replacing parts without knowing the real problem or cause is spending money for the fun of it.
Do what Morris said first. Get the oil checked for excessive coolant. If the head or block is cracked, plenty of coolant and/or oil will be evident. Could be something as simple as some emission parts failing or spark plugs installed incorrectly.
1. It's a Bronco with a 351W in it.
2. I replaced a cracked manifold (VERY COMMON) on a similar vintage F-150 about two years ago. The manifold that was being replaced was already a replacement. It is VERY COMMON on the trucks. Not on the cars.
3. Never heard of a cracked exhaust manifold on a Ford? Seriously? My Expedition cracked one last year. My parent's Expedition cracked one the year before. This is FAR from a rare event.
4. I'm not telling him to go blindly buy a set of bloody headers. Find the leak first. If it is a cracked manifold, there will likely be visible carbon on the manifold where it is cracked. You can feel around for the exhaust leak as well. Headers are less expensive than manifolds, which is why I suggested them, and they will bolt to the stock exhaust.
It is FAR more likely that it is an exhaust leak caused by a broken exhaust stud, the EGR tube rusting off, or a manifold cracking than it is anything mechanically wrong with the engine.
Threads on the topic:
http://www.ford-trucks.com/forums/650395-what-will-a-cracked-exhaust-manifold-do.html
http://www.plowsite.com/showthread.php?t=85966
http://www.ford-trucks.com/forums/1050640-5-8-exhaust-manifolds.html
