Who has experience with DIS waste spark systems? Before COP took over, waste spark DIS were very common, and there are quite a few still in service. If any of you have changed plugs on a system like this, you'll notice half of the plugs show wear on the center electrode while the others remain virtually perfect. This is because there are two cylinders being fired by one coil. The two cylinders fired by one coil are referred to as "running mates" and are paired by being on opposite cycles (one fires on compression and the other 'waste sparks' on the exhaust).
Now, each coil running the mate cylinders has a reversed polarity on one output. So one plug always fires the spark from the electrode to the ground strap, while the other running mate cylinder fires from the ground strap to the electrode. Put another way, assuming an example of 35KV discharge voltage, that means that relative to Common ground (as in the cyl.head/vehicle body) plug A fires at +35KV and plub B fires at -35KV. With this, the plug firing a positive 35KV will see (proton-induced) wear on center electrode, and the other firing at negatve 35KV will see wear on the ground strap (for the same reason) but most often much less so, meaning that at plug replacement interval, one plug looks destroyed while the other remains virtually perfect.
NGK explains all of this better:
https://www.ngk.com/glossary/8/spark-plug/w
All the rambling is just so even if someone is not familiar with this system, they too can offer their opinions to the big question:
Why not even plug wear halfway through the change interval, by swapping the wire boots at the coil, between the running mates?
After all these years, I've JUST explerimented with it recently, one GM and one Ford. Although just a week or two into the experiment, no issues, both run smooth.
Can anyone think of something I might have overlooked bc I havent seen it mentioned before
