- Joined
- Jun 2, 2002
- Messages
- 4,661
For discussion, what do you think would cause my evaporative emissions canister to fill with water? At approx. 37,000 miles my 2017 Nissan Frontier w/2.5 liter engine started having difficulty taking on fuel. This weekend I had the opportunity to investigate the issue and found that my charcoal canister was full of water.
I removed all of the vapor lines and ensured they were clear and I inspected everything to verify that no cracks or leaks existed in the system. The only line I found with moisture was the canister vent line which vents to atmosphere and is controlled by the vapor vent solenoid. The vapor vent control solenoid and the pressure sensor both worked as designed and I had no DTCs or CELs related to this situation.
The only thing I found out of the ordinary is the vent line with the moisture in it. This line vents to the fuel filler neck (on the outside - not internally) and is open to atmosphere exactly where the fuel cap threads on. There is a seal that seals the fuel filler neck and it wasn't seated. I didn't pay enough attention during removal to notice whether the tiny drain hole in the seal was at the bottom where it is supposed to be. There is no splash shield around the filler pipe to keep water from spraying on the filler neck or vent line and we had an unusually wet December so this may be the problem.
Has anyone else had such an issue with water in their charcoal canister? I did drain the water and purged the canister with compressed air to dry it out. The service manual states that if the canister weighs over 2 Kg (4.4 lbs) to replace it. Mine weighed nearly 6 lbs before I dried it.
