Hello Everyone,
I can see that some of the 'Low SAPS' oils have Porche C30 specification which apparently is dealing well with engine wear protection:
I don't think I ever saw any other spec with such good results in Librizol. Does it mean that if you live in Europe you should normally stick with Low SAPS oils?
I live in Switzerland and it is illegal to sell in (or import to) Switzerland fuels (petrol & diesel) with more than 10 ppm of sulfur. So the fuel must be of good quality. Does it mean I have to forget about ACEA A3/B4 specs and simply use ACEA C2 and C3 with Porche C30 for best results?
Even when doing occasional visits to EU (France, Germany, Italy) it seems like in EU they use Euro-5 fuels since 2009 which also limits sulfur to 10 ppm.
Somehow I see a shift in European Castrol Edge line towards Low SAPS even for petrol engines. If I use the Castrol Lube adviser in Switzerland it recomends Castrol Edge 5w30 ACEA C3 for my Nissan petrol engine.
Currently I am using ACEA A3/B4 Valvoline SynPower 5w30, however I feel that if fuel is so good I can simply switch to Castrol Edge 5w30 ACEA C3 and have a longer life of catalytic converter. My OCI are around 10k to 12k of kms. Official Nissan dealers do OCI every 15k of kms and use ACEA A3/B4 oils.
What do you think?
What do you think?
