Esso XD 0-W30 05 Vibe
Southern Ontario
4,200 miles on oil (Dec to March winter driving in Toronto)
27,000 miles on 1zzfe engine
ESSO XD 0-W30
YZZF2 oil filter
40/60 city/hwy driving
4L oil capacity
3 Dixie
cups of top up oil
From WEARCHECK
Iron 5.9
Lead 0.1
Aluminum 2.9
Copper 2.1
Chromium 0.4
Nickel 0.0
Titanium 0.1
Tin 0.3
Silver 0.0
Silicon 12
Potassium 0.8
Sodium 0.7
Boron 1.3
Barium 0.6
Calcium 3211
Magnesium 17
Moly 7.2
Phosphorus 1123
Zinc 1283
Sulfur 3774
Sulfation 65
Nitration 118
Oxidation 72
Visc@100Cel 9.2
Fuel% 0.0
Glycol% Water% Soot% 0
Is this with a stock intake? Consider a new air filter if you haven't changed it yet.
I had changed it once but from what I have seen on this site the Vibe air intake has problems keeping out the dirt.
Oxidation 72 ? Nitration 118 !!? With only 4200 miles on XD-3 ? Something isn't right there. If those numbers are correct, that alone is cause for concern.
Viscosity of 9.2 on a pure synthetic that starts out at 12.1 ? Something isn't right there either. I recall UOA from XD-3 with 10K miles on the oil and it had slightly thickened, not sheared down.
All that said, the wear numbers do look pretty good.
I admit that I don't know this particular engine at all, but I'm surprised that it could be that hard on this oil after only 4200 miles. But maybe !
12 isn't bad. Blackstone shows the univ. avg. at 11. You're fine. The airbox can be a little tricky to get sealed back up properly, but yours most likely is.
You beat up the XD3. Sheared it down some.
But, everything else looks excellent.
