I have a Dell XPS410 (DXP061) and am having trouble getting 64-Bit Windows 7 Professional installed on it. During the "Expanding Windows files" stage of the installation, I get an error stating:
Windows cannot install required files. The file may be corrupt or missing. Make sure all files required for installation are available, and restart the installation. Error code: 0x80070570
I have tried 4 different ISO images that I have access to and tried both DVDs that I burned and creating bootable USB memory sticks. I've Googled the problem for the past two days and tried everything I could find, including swapping memory, removing memory, different BIOS settings, using the other optical drive, etc.
I can install 32-Bit Windows 7 Professional without any problems. I don't understand, this machine previously had 64-Bit Windows 7 on it and I was just trying to wipe it clean and start fresh as I repurposed it.
The machine is basically as shipped from the factory. The memory was upgraded to 4 GB - 1 GB in each slot. And the hard drive might have been upgraded along the way and is currently a Western Digital WD3200KS-75PFB0 320 GB SATA.
Please help if you can. This is driving me nuts!
