2001 Subaru Forester.
A couple of years ago I used those big refrigerant cans of "Arctic/polar freeze" stuff at Walmart because I thought my car was low on Freon. You know... it's the one with the built in gauge on the line, and I think I had added the UV dye leak detector too. This summer the clutch (I think), doesn't catch all the time, I escaped some of the green dye in the line out by just pressing the valve on the low side, and then the A/C seems to work well for a few days. When it cycles, I hear a faint "Whoosing" sound with a sharp cutoff in the cabin as if air is getting sucked into a vacuum and then the door instantly closed. Not sure if any of that makes sense, but I'm trying to figure out if my compressor is on its last legs or just operating in a failsafe mode because the line is either clogged or too much refrigerant is in the system.
Thanks for any help.
