Equivalent to AC DELCO PF52 with Thread M20X1.5
Lake Forest, CA
Looking for spin-on oil filter similar to AC DELCO PF52 with thread 20mm x 1.5mm
AC DELCO PF52
Thread size: 18mm x 1.5mm
Diameter: 2.970 Inch
Height: 4.960 Inch
Looking at the gasket size and thread size, this is pretty close:
DONALDSON P552849
Outer Diameter: 2.96 Inches (75 MM)
Thread Size: M20 x 1.5
Length: 4.76 Inches (121 MM)
Gasket OD: 2.76 Inches (70 MM)
Gasket ID: 2.40 Inches (61 MM)
Efficiency 99%: 36 Micron
Efficiency Test Std: SAE J1858
Anti Drain Valve: Yes
Bypass Valve Setting: 11-17 PSI (0.8-1.0 BAR)
Price Type: F
Cross references to a Wix 51347
Originally Posted By: The_Eric
Wix 51036 / NAPA Gold 1036
Wrong thread size.
Originally Posted By: KCJeep
Fram 3980 series also.
Wrong thread size.
Thanks Merkava.
Looks like DONALDSON P552849 and Wix 51347 have the correct thread size. Cross reference to Fram is PH2849A, no Tough Guard nor Ultra is available.
