Originally Posted By: vwalburn
Have a 2011 Equinox coming up on 4400 miles. Want to decide on what oil to use at the first oil change. Couldn't get a good answer from GM as to the factory fill in the 2.4L 4 cyl. Want to use a dexos1 oil so my choices are: Pennzoil Platinum, Mobil 1 or Quaker State UD. Amsoil XL says that it meets dexos1 standards but is not licensed on the official GM dexos website;
http://www.gmdexos.com/licensedbrands.html
What's everyone's opinion on all this?
FF is Mobil brand oil.
You actually don't have to use Dexos oil. Right in your owner's manual it says if it is not available you can use API Starburst oil. I would not sweat having to use a Dexos oil. Just be sure it is API Starburst certified if the brand you want to use did not certify for Dexos. Rememebr, GM says right in the owner's manual you can use something other than Dexos!
Originally Posted By: 2001 Equinox Owner's manual
Use of Substitute Engine Oils if
dexos is unavailable: In the event
that dexos approved engine oil is
not available at an oil change or for
maintaining proper oil level, you
may use substitute engine oil
displaying the API Starburst symbol
and of SAE 5w30 viscosity grade.
Amsoil XL is API Certified with the Starburst so it is fine to use.
