Out of necessity, I discovered a trick for starting an engine with plugs that just keep getting fouled (loose carbon and oil from piston soak). After an hour of trying things like cleaning the plugs with carb cleaner, and using new plugs, I tried this:
I squeezed the plug gaps WAY down, to about 1/2mm or 0.02 inch, and the engine fired up easily. I let it run for a while to clear out the oil, let it cool, put in the new plugs, and everything was fine after that.
GM should print this on the label of their Top Engine Cleaner.
