Heres my issue.
Soon Ill be tearing the car down for a cam install (s/c 3800). Coolant has a tendency to make its way into the engine during the install at times. The general procedure is to fill with a cheap oil, run the car for a minute, shut it off and drain it, etc. However, some people still spin a bearing as a result.
What can I use to protect against spinning a bearing? I have a feeling that just running new oil through it wont help.
Thanks
Thanks
